December 3, 2020 at 9:27 am
Forum ModeratorOccasionally people will send links to the Help system rather than give a reference. These trigger a password check on the Ansys system, but.....
For anyone who is having the same problem as I have, i.e., not being able to access the URL (shows Customer Portal Login). You can access these links by:
- First open the help section of Ansys through the software ( ? button on the upper-right side of the Fluent Solver User Interface: This opens help in a browser)
- Copy the link you want to access
- Past it in browser URL (new tab) where the help documentation had been opened.
You can access these links. Just in case this helps someone.
Thanks to @smalbro93 for the hint.
December 3, 2020 at 11:07 amKeyur Kanade
Ansys EmployeeThanks Rob!
December 4, 2020 at 3:54 amsmalbro93
Subscriberthank you.
January 4, 2023 at 8:05 pmMohammad Nasreddine
SubscriberHello Mr. Rob,
I am not quite sure where to paste the link I copied.
Can you please help me?
This is the link I am trying to reach:
https://ansyshelp.ansys.com/Views/Secured/Doc_Assets/v222/CFX/buoy.zip
It's an example tutorial I found in ANSYS CFX Tutorials. I am in desperate need of this file to continue the tutorial because it's for my final year project.
May 8, 2023 at 5:24 pmAhmed Shayor
SubscriberThank you so much
Viewing 4 reply threads- The topic ‘Using Help with links’ is closed to new replies.
5899
1306
