July 6, 2024 at 8:07 am
Basit Khan
SubscriberI am conducting a wave spring analysis in ANSYS to determine the damping ratio using harmonic analysis. I've performed a modal analysis to find the natural frequencies and then conducted a harmonic analysis, resulting in an amplitude vs. frequency graph.
Can I use the half-power bandwidth method to extract the damping ratio from this graph? I want to compare these simulation results with those obtained from an impact hammer test. Is this method suitable for such a comparison, and how can I accurately extract the damping ratio from the simulation results?
July 24, 2024 at 2:39 pm
ashish.khemka
Forum ModeratorHi,
Please see if following link helps you: Finding Damping ratio theoretically (ansys.com)
Ashish Khemka
- The topic ‘Using Half-Power Bandwidth Method to Determine Damping Ratio from Harmonic Analy’ is closed to new replies.
