May 1, 2023 at 11:52 pm
Nirvan Gajadharsingh
SubscriberHello,
solving for the FDE modes in my waveguide gives fields in Ex, Ey, Ez, Hx, Hy and Hz. The Ey field is shown in the built-in viewer as:
when I use the command :
Ey_mode1 = pinch(getdata("mode1","Ey"))
I get an array with all elements assigned with a value of 0. The same thing happens for Hy.Â
This does not happen with Ex_mode1,Hx_mode1,Ez_mode1 and Hz_mode1. Both Ey and Hy have fields which are shown in the built in viewer, yet when this data is exported to array , all the elements of the array gets stored as 0.
Can someone please explain why this is happening and how I can get the data associated with the Ey and Hy modes?Thanks
May 2, 2023 at 8:43 pm
Guilin Sun
Ansys EmployeeYour script is correct. Make sure you visualize the same Ey.
You can also use
E=getresult("mode1","E");
to get the vectorial fields, and then extract Ey from the dataset;
Ey=E.Ey
May 3, 2023 at 2:03 pm
Subscriberthanks for clarifying.
- The topic ‘using getdata to grab mode profiles’ is closed to new replies.
5824
