May 6, 2023 at 7:02 am
Md_Salem
SubscriberI am doing modal analysis for some structure using Workbench 21R2.
I need to extract the value of the first (Fd) frequency to a text file (MODE_F.txt) on my computer desk top, so I used the next APDL commands in the solution box :
*GET,Fd,MODE,1,FREQ
*CFOPEN,MODE_F,TXT,C:\Users\MD\Desktop
*VWRITE,Fd
(F18.10)
*CFCLOSE
Unfortunately, the file was created at the required location, but the value inside it was (0.0000000000), despite the deformation of the target modes in the solution box with their frequency values. What would be the reason for that ?
Another issue .... if i need to make a text file contain more than one frequency , what would be the APDL command format?
thanks
May 8, 2023 at 12:31 pm
Chandra Sekaran
Ansys Employeecan you do a SET,LIST to list the frequencies (example commands below) just to see what the frequencies are. The responses to these commands will be in the solution information or solve.out file.
/post1
set,list
*get,f1,mode,1,freqÂ
You can use C format which is sometimes easier. For example to print 3 frequencies f1,f2,f3 you can use
*vwrite,f1,f2,f3
%e, %e, %e
May 8, 2023 at 2:58 pm
mrife
Ansys EmployeeHi Md_Salem
Getting the Mode with that method is possible when MAPDL is in the Solution module but after the solve. When post processing the style of the *GET command is different. Instead use the SET command to read in the specific mode, then get the frequency of the result set. Like so:
set,1
*get,Fd,active,0,set,freq
Continue on with opening and writing to the file.
Mike
May 8, 2023 at 6:53 pm
Md_Salem
SubscriberHi Mike,
I used next command just as you suggestedÂ
set,1
*VWRITE,Fd
(F18.10)
*CFCLOSEUnfortunately the file named "MODE_F.txt" wasn't created at all.
when Itried my old code it was created but with Null value (0.00000000)
May 8, 2023 at 6:58 pm
mrife
Ansys EmployeeÂ
What does the output file for the post processing commands object show for the file opening/writing/closing? Try right-clicking the Solution object and clearing the generated data. Then running the solve again. Does this result in the file being created?
- The topic ‘using *get command’ is closed to new replies.
- APDL, memory, solid
- Meaning of the error
4052
1487
