February 21, 2023 at 5:26 pm
February 22, 2023 at 5:32 pm
John Doyle
Ansys EmployeeI am not aware of a documented limitation to this combination. Â
Are you including 'RATE,on' in /SOLU before executing the SOLVE?
If yes, does your usercreep.F work as expected when usermat.F is excluded?
February 22, 2023 at 5:47 pm
sobhanis
Subscriberthe point is i want to use usercreep and usermat at the same time but only usermat workes and i can't see usercreep results there . still with RATE,on it doesn't show anything there for creep.Â
February 22, 2023 at 6:49 pm
John Doyle
- The topic ‘usercreep.F and usermat .F’ is closed to new replies.
