March 3, 2022 at 4:31 pm
DoodlerD
SubscriberHi,
How can I scope nodal elemental results from a local coordinate system? The user defined result scoped for a node reverts back to the global co ordinate system.
March 3, 2022 at 5:43 pmMarch 9, 2022 at 3:18 pmAshish Khemka
You can change the coordinate system before evaluating the results or duplicate the result without data and then evaluate the result after changing the result.
Regards Ashish Khemka
March 10, 2022 at 2:42 pmDoodlerD
SubscriberI found that ENFOVECTORS does not work in local co-ordinates, but ENFOX/ENFOY/ENFOZ work. These details are not mentioned in the APDL manual.
November 26, 2023 at 5:58 amMuhammadAhsanZeeshan
SubscriberHello Everyone,
I made surface along my local coordinate at my 3d model in ANSYS workbench 2022 R1. I want to export normal stress data in my local coordinate. when i export normal stress data, it will obtain along global coordinate. But I want normal stress exported data in local x, y and z coordinates not along global coordinate.
Viewing 4 reply threads- The topic ‘User Defined Results in the Local Coordinate system’ is closed to new replies.
5664
1890
1414
1304
