January 30, 2024 at 9:02 am
Jacopo Bardiani
SubscriberHi, I would like to implement a user defined result like Total deformation * 1.5.
Which is the code for "Total deformation" to insert in the field "Expression" of the "User defined result"?
Thanks,
Jacopo
January 30, 2024 at 9:52 am
ErKo
Ansys EmployeeÂ
It is called USUM
–Â
also see the worksheet results for names.
/forum/forums/topic/worksheet-result-ansys-mechanical/
Finally check out also the identifiers as they can be used for creating user define results – see here for an example:
https://www.padtinc.com/2011/09/01/using-the-identifier-for-mechanical-post-processing/
All the best
Erik
- The topic ‘User defined results’ is closed to new replies.
1890
1419
1304
