September 25, 2019 at 11:37 am
vipinpuli
SubscriberHow to create a user defined results ? if i want to make sum of minimum principal stress and medium principle stress ?
September 26, 2019 at 12:58 am
peteroznewman
SubscriberClick on Solution branch, click on the Result Tab and click on the User Defined Result button.
In the yellow field type S2+S3
Evaluate All Results.
The expression S1 is the maximum principal stress.
October 2, 2019 at 7:08 pm
vipinpuli
Subscriberthank you it is working , could you please tell me , from where we can get these short codes from ? s1 , s2 and a3 ?Â
October 2, 2019 at 7:40 pm
peteroznewman
SubscriberClick on the Solution branch in the Outline, then click on the Worksheet button on the Solution tab of the ribbon. The column labeled Expression is the "code".
March 20, 2023 at 3:30 am
Wokil bihar
SubscriberHow to do johnson noise analysis in ansys?
after thermal electric analysis, how to see thermal noise?
Thank you!
March 20, 2023 at 8:17 am
Erik Kostson
Ansys EmployeeHi
This is a very old post - can you create a new one and explain in details what you would like to do and get out of the analysis.
All the best
Erik
- The topic ‘USER DEFINED RESULTS’ is closed to new replies.
- APDL, memory, solid
- Meaning of the error
4162
1487
1318
1170
