TAGGED: 3d-geometry, beam-analysis, user-defined-result
June 30, 2023 at 9:33 am
Kevin Gnanaraj
SubscriberIs there a way to get a variable such as the total length of an imported geometry along one axis within the model view? I'm trying to get the deformation per unit length from the origin of a beam constrained at the centre with a load distribution as a user defined variable.
June 30, 2023 at 5:11 pm
Armin
Ansys EmployeeHi Kevin,
You can define a path by right-clicking on the "Model" in the project outline and then select insert --> Construction Geometry --> Path.
Once a path is specified, you can simply request the variable of interest (for example, total deformation) to be plotted along the path. Right-click on Solution and select the variable of interest, then for the entry, Scoping Method, select "Path" and finally select your prescribed path defined earlier along the beam.
July 6, 2023 at 7:39 am
Kevin Gnanaraj
SubscriberThank you, I was able to define a path, what are the differences between LOC_DEF and LOC? Both of them have the unit "displacement"
July 6, 2023 at 3:41 pm
Armin
It appears that LOC provides the location of each node while LOC_DEF provides the deformation of each note. Please see if the thread below is helpful to you:
/forum/forums/topic/export-nodal-coordinate/
- The topic ‘User defined result for imported geometry’ is closed to new replies.
3562
1103
1063
1045
947
