May 7, 2024 at 8:16 am
Ken Ng
SubscriberHi,
I want to create a graph to visualise the friction coefficient changes of my model, and I have looked through the model on this page /courses/index.php/courses/topics-under-connections-in-ansys-mechanical/lessons/defining-dynamic-friction-coefficient/
As I don't see there isn't any specific input to define the CONTNMISC62, I thought it is a default expression. But when I take this to my model, it gives an error message that "the result data is not contained in the result file"
I wonder how should I use this CONTNMISC62 expression
May 8, 2024 at 7:57 am
Sampat Kumar
Ansys EmployeeHiÂ
Did you perform the same model setup on your side as in the example in Ansys? It seems that it could be related to the contact issue. Which Ansys version are you using?Â
Best Regards,
SampatÂ
May 8, 2024 at 12:24 pm
- The topic ‘User Defined Result – CONTNMISC62’ is closed to new replies.
5734
