User Defined Particle-Wall Interaction via wall film: how many max. fragments?
    • nilotpalc
      #question Hi everyone, I have a very simple question. I am writing a user defined Fortran subroutine for particle-wall interaction via a wall film, and was referring to the following code documented in the page (8.6.3.1.3. User Defined Particle-Wall Interaction) of CFX Solver Modelling Guide. The question is about a single line in this code:   REAL   FACT, ANGLE, VEL_PT(3), DIAM_PT, NRATE_PT,
           &       BRKUP_IND(3), CHILD_DIAM(3), CHILD_NRATE(3),
           &       CHILD_COEF_N(3), CHILD_COEF_P(3), CHILD_MODE(3), DENS_FL
      Is increasing the size of BRKUP_IND array allowed in CFX? I have tried doing BRKUP_IND(10), which means a particle can generate 10 fragments. The simulation ran without any error and a single particle did end up generating 10 fragments. However, the CFX engineers put this line on the page containing this code: "Note that a maximum of 4 child droplets may be generated with the child generation model." What do they mean here? Maximum of 4 fragments by this code or in general? Although I tested with 1 particle, I am concerned it might not work for say a million particles and I might get an "overflow" error. Could anyone of you throw some light on this? I didn't post on CFD Online because some smart people there deviate from answering the question and ask to run a simulation and check. In my case, I already did that, so I think AIS is the right place to ask. Thank you!
       #include "cfx5ext.h"
      dllexport(pt_wall_splash)
            SUBROUTINE PT_WALL_SPLASH (NLOC,NRET,NARG,RET,ARG,CRESLT,
           &                           CZ,DZ,IZ,LZ,RZ)
      CC
      CD User routine: template for particle user routine
      CC
      CC --------------------
      CC        Input
      CC
      CC  NLOC   - number of entities
      CC  NRET   - length of return stack
      CC  NARG   - length of argument stack
      CC  ARG    - argument values
      CC
      CC      Modified
      CC
      CC        Output
      CC
      CC  RET    - return values
      CC
      CC       Details
      CC
      CC======================================================================
      C
      C ------------------------------
      C     Preprocessor includes
      C
      #include "cfd_sysdep.h"
      #include "cfd_constants.h"
      C
      C        Argument list
      C
            INTEGER NARG, NRET, NLOC
      C
            CHARACTER*(4) CRESLT
      C
            REAL ARG(NLOC,NARG), RET(NLOC,NRET)
      C
            INTEGER IZ(*)
            CHARACTER CZ(*)*(1)
            DOUBLE PRECISION DZ(*)
            LOGICAL LZ(*)
            REAL RZ(*)
      C
      C=======================================================================
      C
      C    Executable Statements
      C
      C
      C     Return variables:
      C     -----------------
      C
      C     Child droplet breakup indicator                       : RET(1,1)
      C     Child droplet diameter                                : RET(1,5)
      C     Child droplet number rate                             : RET(1,9)
      C     Child droplet normal coef of restitution              : RET(1,13)
      C     Child droplet parallel coef of restitution            : RET(1,17)
      C     Child droplet mode                                    : RET(1,21)
      C
      C     Argument variables
      C
      C     Particle impact angle                                : ARG(1,1)
      C     Particle velocity                                    : ARG(1,2)
      C     Particle diameter                                    : ARG(1,5)
      C     Particle number rate                                 : ARG(1,6)
      C     Fluid density                                        : ARG(1,7)
      C
      C     We know that NLOC is 1 for the particle user source routines!!!!
      C
      C-----------------------------------------------------------------------
      C     Calculate the return variables
      C
            CALL SPLASH (RET(1,1),RET(1,5),RET(1,9),RET(1,13),RET(1,17),
           &             RET(1,21),ARG(1,1),ARG(1,2),ARG(1,5),ARG(1,6),
           &             ARG(1,7))
      C
            END
      C
            SUBROUTINE SPLASH (BRKUP_IND,CHILD_DIAM,CHILD_NRATE,
           &                   CHILD_COEF_N,CHILD_COEF_P,CHILD_MODE,
           &                   ANGLE,VEL_PT,DIAM_PT,NRATE_PT,DENS_FL)
      C
      C
      C
      C---- Do not change these defines, they have to be consistent with what
      C     the solver uses
      C
      #define   __regular_particle__ 1
      #define      __wall_particle__ 20
      #define     __pt_uf_get_data__ 1
      #define    __pt_uf_save_data__ 2
      #define        __pt_uf_iseed__ 1
      #define        __pt_uf_pmode__ 2
      C
      C        Argument list
      C
      C
      C        Local variables
      C
            REAL    SIGMA, VISC_PT, R, SPEED_PT, ANGLE_DEG, ALFA, BETA,
           &        GAMMA, VEL_NORM, OH, RE, K, M1M0
            INTEGER ICHILD, ISEED, ACTION
      C
      C    Executable statements
      C
      C     Prologue
      C
      C---- Initialization
      C
            ICHILD = 0
      C
      C---- Get particle seed info (needed for random number generator)
      C
            ACTION = __pt_uf_save_data__
            CALL USER_PARTICLE_INFO(ACTION,__pt_uf_iseed__,ISEED)
      C
      C---- Some material properties (water)
      C     --> Surface tension coefficient
      C     --> Particle viscosity
      C
            SIGMA   = 0.0201
            VISC_PT = 0.001
      C
      C---- Random number (required for deviation angle)
      C
            CALL GET_RANDOM(R,1,ISEED)
      C
      C     Computation Section
      C
      C---- Particle velocity magnitude and impact angle
      C
            SPEED_PT  = SQRT(VEL_PT(1)**2 + VEL_PT(2)**2 + VEL_PT(3)**2)
            ANGLE_DEG = ANGLE*180./PI
      C
      C---- Ohnesorge and Reynolds number
      C     --> Re, based on wall normal impact velocity!
      C
            VEL_NORM = SIN(ANGLE)*SPEED_PT
            OH = VISC_PT/SQRT(DENS_FL*DIAM_PT*SIGMA)
            RE = DENS_FL*DIAM_PT*VEL_NORM/VISC_PT
      C
      C     Precompute reflection angle
      C
      C---- Impact angle, ALFA, average reflection angle, BETA. Add random
      C     deviation angle, GAMMA, if ALFA < 15 deg.
      C
            ALFA  = 90.   - ANGLE_DEG
            BETA  = 61.88 + 0.326*ALFA
            GAMMA = 17.6  - 0.18*ALFA
      C
            IF (ALFA .LT. 15.) BETA = BETA + (R-0.5)*GAMMA
      C
      C---- Compute K-value
      C     --> Clip K to avoid overflow during m1/m0 calculation
      C         (221^9.2133 = 3.9773E+21)
      C
            K = MIN(OH*RE**1.25,221.)
      C
      C     K <= 57 -> Particle deposited at wall
      C
            IF (K .LE. 57) THEN
      C
              ICHILD = ICHILD + 1
              BRKUP_IND(ICHILD)    = 1.
              CHILD_DIAM(ICHILD)   = DIAM_PT
              CHILD_NRATE(ICHILD)  = NRATE_PT
              CHILD_COEF_N(ICHILD) = 0.0
              CHILD_COEF_P(ICHILD) = 0.0
              CHILD_MODE(ICHILD)   = __wall_particle__
      C
      C     ... else partially reflected
      C
            ELSE
      C
      C---- Mass fraction across reflection
      C
              M1M0 = 3.9869E-21*K**9.2133
      C
      C---- Reflected portion of particle
      C
              ICHILD = ICHILD + 1
              CHILD_DIAM(ICHILD)   = DIAM_PT*M1M0
              CHILD_COEF_N(ICHILD) = COS(BETA*PI/180.)*SPEED_PT
              CHILD_COEF_P(ICHILD) = SIN(BETA*PI/180.)*SPEED_PT
              CHILD_MODE(ICHILD)   = __regular_particle__
      C
      C---- Deposited portion of particle
      C
              ICHILD = ICHILD + 1
              CHILD_DIAM(ICHILD)   = DIAM_PT*(1. - M1M0)
      C
            ENDIF
      C
      C     Epilogue
      C
      C---- Update ISEED in particle database with value computed in
      C     this routine
      C
            ACTION = __pt_uf_get_data__
      C
            END
    • Mark O
      Hi, you might get an overflow or memory error. The reason the help says "Note that a maximum of 4 child droplets may be generated with the child generation model." is becuase PT_WALL_SPLASH chops the single return array into chuncks of 4 as RET(1,1), RET(1,5), etc. You could chop it into larger chunks but it is not clear to me whether sufficient memory will get allocated. I am waiting for the developers to get back to me.
    • Mark O
      You can set the maximum number of children created at breakup using the expert parameter:
      pt real droplet breakup max children
      It doesn't appear in the user interface as an available expert parameter, but you can insert an expert parameter object into the tree in CFX-Pre and with a right mouse click on it select the option to edit in the command editor. Then you can insert
      pt real droplet breakup max children = 10
      You should then have in PT_WALL_SPLASH
      C     Return variables:
      C     -----------------
      C
      C     Child droplet breakup indicator             :RET(1,1)
      C     Child droplet diameter                      :RET(1,11)
      C     Child droplet number rate                   :RET(1,21)
      C     Child droplet normal coef of restitution    :RET(1,31)
      C     Child droplet parallel coef of restitution  :RET(1,41)
      C     Child droplet mode                          :RET(1,51)
      and
      CALL SPLASH (RET(1,1),RET(1,11),RET(1,21),RET(1,31),RET(1,41),
           &             RET(1,51),ARG(1,1),ARG(1,2),ARG(1,5),ARG(1,6),
           &             ARG(1,7))
      and in SPLASH
      REAL  BRKUP_IND(10),CHILD_DIAM(10),CHILD_NRATE(10),CHILD_COEF_N(10),
           &              CHILD_COEF_P(10),CHILD_MODE(10)
      REAL  ANGLE, VEL_PT(3), DIAM_PT, NRATE_PT, DENS_FL
    • nilotpalc
      Hi Mark,
      This is very helpful, thanks so much for digging this out!
    • nilotpalc
      Hi Mark and everyone,
      I have a question related to this code. This code is called for each particle track when it interacts with a wall. Now if I want to write the values of intermediate variables (say the random number R from the line CALL GET_RANDOM(R,1,ISEED))to an external file or just print it on the console everytime the user routine is called, how do I do that? I can write a similar code that generates a random number, say in Python, but am afraid I will end up with a different random number. So, it’d be great if I had access to the random number or any other intermediate value calculated in the particle user routine itself.
      Thank you!
Viewing 4 reply threads
