November 15, 2024 at 9:15 am
786959915
SubscriberIn the process of secondary development of user-defined equations of state, what aspects should be paid attention to in the update of temperature and time? Also, do you have any advice for beginners in secondary development?
November 19, 2024 at 11:23 pm
Pedram Samadian
Ansys EmployeeHi,
The consistency between the temperature update and energy balance in the system, the update of the temperature-dependent parameters such as specific heat capacity or heat transfer coefficent, and the compatibility between the update approach and applied time-integration scheme (explicit or implicit) are essential when working on the secondary development of user-defined equations of state in LS-DYNA.Â
Please check the LS-DYNA Theory Manual (LS-DYNA Theory Manual) and Keyword User’s Manual Vol. 1 – Appendix B (LS-DYNA Keyword Manual) for further information.
Some advice for you:- Test your code with simple problems before moving to complex simulations.
- Add checks in your code to catch unphysical values (e.g. negative densities, infinite temperatures).
- Compare your EOS implementation with experimental data or benchmark problems to ensure accuracy.
I hope this helps.
Thanks,
Pedram
November 21, 2024 at 12:28 pm
786959915
SubscriberThank you very much for your reply, I will make an effort according to your suggestions。
