User button – Python commands
    • jean.collomb
      I am trying to create a user butter in order to accelerate my post-processing in Ansys Mechanical.
      My dream when I click on the button is :
      1- Create one folder with : total displacement ; 3 directional displacements ; VM stress
      2- Create one folder for a specific name selection with : total displacement ; 3 directional displacements ; VM stress
      3- Export these results (min/max values) in a csv file.
      I found this command for the total displacement : ExtAPI.DataModel.Project.Model.Analyses[0].Solution.AddTotalDeformation()
      But I don't know how to fin other commands for directionnal displacements, VM stress, for creating folders, exports results ...
      Thanks you for your help :)
      Jean
    • ErKo
      Hi
      You can use the record in the mechanical scripting console, and add the directional deformation , etc., and you will see the commands (e.g., AddDirectionalDeformation(), AddEquivalentStress(), etc.)
      On how to het the max/min from these results, one can get that by:
      equivalent_stress = ExtAPI.DataModel.Project.Model.Analyses[0].Solution.AddEquivalentStress()
      MaxVMSt=equivalent_stress.Maximum
      Then export MaxVMSt to a csv file. Search the internet how to export there are many posts on that, e.g., :
      https://www.programiz.com/python-programming/writing-csv-files
      Finally group is a bit hard, but not really needed in order to create the results, extract max/min and export these values.
      If needed folders/groups look at the below link for an example that adds these results and puts them into a folder.
      https://discuss.ansys.com/discussion/2540/how-can-add-certain-results-and-group-them#latest
      All the best
      Erik
    • jean.collomb
      Hi Erik,
      Thanks a lot for your answer!
      I try with a simple code, and it works!
      I have two more questions:
      1- Is there any documentation to easily get these informations ?
      2- I try to create a displacement result for a named selection, but the record is incomplet I guess. I get the command bellow where the scoping method is "named selection", but I don't know how to affect a named selection.
      total_deformation_45 = solution.AddTotalDeformation()
      total_deformation_45.ScopingMethod = GeometryDefineByType.Component
      Thanks a lot,
      Jean
      nb : I did not try the export for now.
      Code example:
      solution = ExtAPI.DataModel.Project.Model.Analyses[0].Solution
      resgr=[]
      # Déplacement selon x, y, z, total
      directional_deformation_global_x = solution.AddDirectionalDeformation()
      directional_deformation_global_x.NormalOrientation = NormalOrientationType.XAxis
      directional_deformation_global_y = solution.AddDirectionalDeformation()
      directional_deformation_global_y.NormalOrientation = NormalOrientationType.XAxis
      directional_deformation_global_z = solution.AddDirectionalDeformation()
      directional_deformation_global_z.NormalOrientation = NormalOrientationType.XAxis
      total_deformation_global = solution.AddTotalDeformation()
      # Contraintes equivalentes Von Mises
      equivalent_stress_global = solution.AddEquivalentStress()
      resgr.append(directional_deformation_global_x)
      resgr.append(directional_deformation_global_y)
      resgr.append(directional_deformation_global_z)
      resgr.append(total_deformation_global)
      resgr.append(equivalent_stress_global)
      dossier_global = ExtAPI.DataModel.Tree.Group(resgr)
      dossier_global.Name = "Global"
    • ErKo
      Hi
      1. See this link: https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/prod_page.html?pn=Customization%20Suite&prodver=22.2&lang=en
      2. See the link here on how to scope results to named selection (if this is not what you want search in the dev. forum): https://discuss.ansys.com/discussion/909/insert-total-deformation-result-in-modal-analysis-scoped-to-a-named-selection-and-define-maximum-and
        All the best
        Erik
    • jean.collomb
      Hi Erik,
      Thanks for your answer.
      Jean
Viewing 4 reply threads
  • The topic ‘User button – Python commands’ is closed to new replies.
