February 1, 2024 at 2:33 pm
Wajih Akleh
SubscriberHello,Â
I am having an issue with linking 2 simulations together (static structural); I want to use the results of the first simulation as the starting point of the second.Â
However, linking "Solution" from case 1 to "Setup" from case 2 doesn't seem to import the results.ÂThank you in advance for your responses and help.Â
February 1, 2024 at 2:53 pm
ErKo
Ansys EmployeeHi
It is better to use one system with multiple steps (the above does not do what is needed).
Search for multiple steps analysis.
https://simutechgroup.com/ansys-workbench-project-page-multiple-step-analysis/
In 2023 R2 and 2024 R1 we also have the restart extension.
/forum/forums/topic/reusing-restarts-from-multi-step-analysis-in-new-analysis/
All the best
Erik
- The topic ‘Use the solution of simulation 1 as the initial state for simulation 2’ is closed to new replies.
