May 13, 2019 at 5:06 am
Memorisexu
Subscriberuse steady result as the initial condition of the transient simulation but required initialization
In Workbench 18.2,I firstly simulate the steady condition using S-A.Then I du the steady "setup" and then open the new "setup"  .In the new Fluent ,I change into transient and want to calculate but it required  initialization
May 13, 2019 at 7:32 am
Amine Ben Hadj Ali
Ansys EmployeeFluent will check for available data if you connect Solution of B with C. That marks its initialization.
May 13, 2019 at 8:47 am
Memorisexu
SubscriberSo as a result, if I want to run the simulation like this ,how I should do? Now I know the common solution is that I can run the steady simulation and then in the same "Fluent" I change it into transient. Can I get my result ?
Best regards,
Xuxu
May 13, 2019 at 8:51 am
Amine Ben Hadj Ali
Ansys EmployeeIf you want in container C to use the B as initialization just connect B Solution to C solution.
May 13, 2019 at 9:02 am
Memorisexu
SubscriberAll right! Just the connection between solution and solution! I will have a try!
Thank you very much !
Best regards,
Xuxu
- The topic ‘use steady result as the initial condition of the transient simulation but required initialization’ is closed to new replies.
- affinity not set
3892
1414
1241
1118
1015
