March 25, 2024 at 9:21 am
Pierre Gardère
SubscriberHello everyone,
I'm trying to simulate an explosion with ALE contact (type Lagrangian_in_solid, ALE_Multi_Material_Group) on a simple mesh box. But I get a strange error message when I start a job:
*** Warning 21292 (STR+1292)
   Load curve ID 37 of *MAT_SIMPLIFIED_RUBBER/FOAM ID 1
   covers only the tensile range. It should include both the
   tensile & compressive range to ensure it describes the
   complete range of loading *** Warning 21293 (STR+1293)
   The abscissa for load curve ID 38 used for material ID 181
   is decreasing. This is not permitted and may result in strange behavior.I had already used mat_181 with the same stress-strain curves without control_ALE, and it worked. Do you have any idea how I can solve this problem? When I start a job with a simple curve in the mat_181 and no table to define the load curve. I don't get this error message.
Thank you for your understanding.Â
March 26, 2024 at 11:12 pm
Reno Genest
Ansys EmployeeHello Pierre,
Ansys employees are not allowed to answer explosion questions on the Ansys Forum. If you are a commercial customer, please create a support case:
customer.ansys.com
Maybe another user will be able to help you.
Reno.
- The topic ‘Use mat 181 in ALE contact’ is closed to new replies.
