January 27, 2021 at 6:38 pm
atif88
SubscriberI was trying to run a simple analysis of 2 bar connected with pin. I tried to define the pin connection as revolute joint. However I received error after running the analysis.
January 27, 2021 at 11:30 pmpeteroznewman
SubscribernYou have a mechanism in the model. One part has zero stiffness in rotation about the Z axis. This causes the solution to fail with the error you see.nIf you go under Analysis Settings, you can turn on Weak Springs, which will automatically add weak springs that will provide a non-zero stiffness to the bodies allowing the solver to compute the results.nFebruary 22, 2021 at 4:24 pmatif88
SubscriberHi Peter,n1)I have turn on the Weak Springs function. When I ran the simulation with force of 5000N, the results seems ok though still need to validify since there is no sign of deformation on the other plate as shown in the picture below:-nn2) After that, I increase the force to 50000N but it seems to be error as shown below:-n
3) Actually, what is the best/accurate way to simulate pin connection?.Really looking forward for your opinion regarding these 3 questions..n
February 24, 2021 at 1:34 ampeteroznewman
Subscribern1) Plot the deformation on one body, not All Bodies.n2) You might need to turn on Auto Time Stepping and set the Initial Substeps to 100. You might also need to turn on Large Deflection.n3) The most accurate way to simulate a pinned connection is to add a pin to the model and use Frictional contact between the pin and the holes.nViewing 3 reply threads- The topic ‘Usage of Revolute Joint as Pin Connection’ is closed to new replies.
- APDL, memory, solid
- Meaning of the error
Top Contributors-
3862
1414
1220
1118
1015
