December 9, 2020 at 11:51 am
Zou_
SubscriberHi everyone, nI'm currently working on an academic project on Ansys about a turbulent flow in a canal and i want to plot Uplus vs Yplus.nI created some custom functions in order to plot that but the plot seems off even though the other results (friction coefficient, wall shear stress) are right.ncan anyone help me ? thank you in advancen -
December 9, 2020 at 12:50 pm
Karthik Remella
AdministratorHello,nCould you please share with us the definitions of your U+ in CFF? Also, you are obtaining the y+ values directly from Fluent, right?nWhich Turbulence model are you using?nAlso, I've moved this question to the Fluids sub-category for better alignment.nThank you.nKarthikn -
December 9, 2020 at 6:33 pm
Zou_
SubscriberHello, nThank you for your response,nI am using SST K-Omega model nFor U+ , i made a custom function to define as U/U-tau nfor Y+ I've tried both using a custom function (Y+ = Y*U-tau/viscosity) and Yplus wall directly from FluentnI just started using Fluent so i'm not exactly surenI want to obtain a plot similar to this one n
n
December 10, 2020 at 1:03 pm
Karthik Remella
AdministratorHi, nWhat does your final plot look like? You need to have a good mesh resolution to capture this plot. Please see this HW problem in our Ansys Innovation Courses (AICs).nCan you please check this example to see if your set-up is overall correct?nThank you.nKarthikn -
December 12, 2020 at 8:22 pm
December 14, 2020 at 1:25 pm
Karthik Remella
AdministratorHello,nThe solution is dependent on your grid. It is important to have a good resolution near the wall. Please resolve the mesh near the wall carefully. You can study the mesh on the case I shared with you as a starting point. nThanks.nKarthikn -
December 17, 2020 at 11:06 am
Zou_
Subscriber -
December 17, 2020 at 12:50 pm
Amine Ben Hadj Ali
Ansys EmployeeAnsys Fluent Theory Guide does cleary mention how uplus and yplus are formulated. By the way almost all solver do not use classic uplus but instead ustar which is built with TKE to avoid getting singular values on stagnation regions.nnOther point: having yplus below 5 is nice but is not sufficient if you are not properly resolving the BL with at least 10-15 cells across it.n
Viewing 7 reply threads
- The topic ‘Uplus vs Yplus’ is closed to new replies.
- affinity not set
- Continuing SAG Mill Simulation with New Particle Batch in Rocky
- Two-way FSI simulation
- Question about generating Porous Jumps
- The result in FLUENT differs from CFD Post
1494
1386
1209
