September 15, 2021 at 1:20 pm
Luca Di Rosa
Subscriberwhat is the correct procedure for upgrading SpaceClaim and Discovery from 2021R1 to 2021R2?
Should i uninstall 2021R1 before installing 2021R2 or can I just run 2021R2 installer and It will do the job?
In case I have to uninstall necessary, which file needs to be backed up?
Thanks
September 16, 2021 at 7:00 am
Devendra Badgujar
Forum ModeratorHi Luca Usually the best practice for upgrading is to uninstall the older version and restart the computer to ensure that the uninstall has processed properly. In case you want to use both the versions, please note that you can run only version at a time else it will create an license conflict. To Download the latest versions please check this page Discovery Downloads - Knowledge Base - Ansys Discovery Forum. Regards. -
September 16, 2021 at 7:07 am
Luca Di Rosa
SubscriberThank you,
which file needs to be backed up then?
September 16, 2021 at 7:16 am
Devendra Badgujar
To the best of my knowledge I don't think any files need to be backed up before uninstalling. The files that you have created using an old version will open in new version.
Regards.
September 16, 2021 at 7:26 am
September 16, 2021 at 12:05 pm
subashni.satish
Forum ModeratorHello Luca
User preferences cannot be saved in Discovery and SpaceClaim user preferences cannot be used for Discovery but they can be used in the SpaceClaim new version.
Custom materials created in older versions of SpaceClaim should be saved in below location.
C:UsersAppDataRoamingSpaceClaimMaterials
File name : Custom (xml file)
This should be accessible to the newer versions.-
September 16, 2021 at 12:55 pm
Luca Di Rosa
SubscriberSubashni Thank you! that's all then.
- The topic ‘Upgrade/Update procedure’ is closed to new replies.
5969
1307
