TAGGED: failure-criteria, macros, mechanical-apdl, upf, user-defined
June 24, 2021 at 5:30 am
AMFCB
SubscriberMy question is regarding user-defined failure criteria in Ansys. To test this feature, I modified the file "userfc.F" to the maximum stress criteria. I then linked this subroutine with ANSYS and created a custom ANSYS.exe file. Now when I run this custom .exe from the APDL launcher, how do I call this user subroutine? For instance, if I were to call the maximum stress criteria directly, I would use:
TB,DMGI,mat#,,4,FCRT
TBDATA,1,2,2,2,2
where, 2 is the maximum stress criteria, and this works well. According to Ansys APDL Material reference, 11-19 are user-defined criteria #1 to user defined criteria #9, but it does not work when I use 11 instead of 2 (see command below):
TBDATA,1,11,11,11,11
What am I missing?
July 21, 2021 at 12:21 pmJohn Doyle
Ansys EmployeeWith regards to using " TBDATA,1,11,11,11,11", you report that "...it does not work"
What exactly is not working? Are you getting an error message? If so, what is the message?
July 27, 2021 at 4:34 pmAMFCB
SubscriberI am not getting an error message, but the results are not right. There is no property degradation and the results are similar to a linear elastic analysis. The stress distribution, if it were coreect, would have been similar to using "TBDATA,1,2,2,2,2". For reference, here is what I modified in the file userfc.F:
#include "impcom.inc"
c
external vmax, vzero
integerelem,matlay,iott, nfcOut, iloc
double precision
xeps(6),sig(6), fc(9),tem,elim(*),slim(*), vmax,vect(9)
c
c
c- nfcOut must be set to 1 or greater if the user subroutine is to be used (see example below)
cnfcOut = 0
c
c
cccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccc
c **** dummy code to avoid analyzer messages. Should be removed by programmer: commented out
cfc(1) = tem*elim(1)*eps(1)*sig(1)*slim(1)*elem*iott*matlay
ccall vzero (vect(1), 9)
c fc(1) =vmax (vect(1),9,iloc)
c
c**** Example to demonstrate user failure criterion coding ****
c******* maximum stress criterion*******
nfcOut = 1
vect(1) = sig(1)/slim(1)
vect(2) = sig(1)/slim(2)
vect(3) = sig(2)/slim(3)
vect(4) = sig(2)/slim(4)
vect(5) = sig(3)/slim(5)
vect(6) = sig(3)/slim(6)
vect(7) = (abs (sig(4)))/slim(7)
vect(8) = (abs (sig(5)))/slim(8)
vect(9) = (abs (sig(6)))/slim(9)
fc(1) = vmax (vect(1),9,iloc)
Viewing 2 reply threads- The topic ‘UPFs – How to call the user-defined failure criteria subroutine in APDL?’ is closed to new replies.
5834
