January 4, 2024 at 3:48 pm
Mario Di Marino
SubscriberHi,
is there any way to import and update a PCB in siwave without having to start a new project?
I can import a PCB but not perform a refresh so for each change made I have to re-import the board as if it were a different project.Thanks,
Mario
January 10, 2024 at 6:35 pm
Mark Frank
Ansys EmployeeImport the new board file in a New SIwave project. Next please go to the export tab in the old project and export a Component File. You can now import this file into the new project by going to the import tab. IF the components just move and you are still using the Same part number and Reference Designator your port setup pingroups and other things will be transfered to the new project.Â
January 10, 2024 at 6:54 pm
Mario Di Marino
SubscriberThanks for your help.
- The topic ‘Update PCB layout in SIwave’ is closed to new replies.
1330
1147
