Update failed for the Fluent Solution component in Workbench
    • roysubhrajit03
      I'm trying to run an with overset meshes a series of different parameter inputs. When I try to update a Design Point from the project schematic, I get "Update failed for Solution component in Fluid Flow (Fluent) for Design Point 0. Update Solution Failed." From that point I can either open up Solution and run it manually abd everything goes fine, or I can open Setup (and do nothing in Setup at all) and update again from workbench and everything works fine. I can also right-clock on the Solution cell in workbench and hit "Update" and it starts working. I am trying to automate my setup and this behavious is really unexpected.
      Can someone please help? I can't figure out what the problem is.
Viewing 0 reply threads
