January 30, 2024 at 7:33 am
Prashant M. P
SubscriberHi, I am having a problem while updating the mesh in Fluid flow (Fluent) in ANSYS 2023R2,Â
It says: (DP 0) The mesh file exporter failed during translation. Please send your data to your support provider.Â
But when I try to do the same problem in ANSYS version 2022R2, I am not getting any error.Â
Can anyone tell me how to rectify it?
January 31, 2024 at 12:38 pm
V.P
Ansys EmployeeHi Prashanth,
Please check out these KMs;Â
Error: Update failed for the Mesh component
Getting error as: Fatal error: Update failed for the Mesh component in Fluid Flow (Fluent)
January 31, 2024 at 1:02 pm
Prashant M. P
SubscriberYes, I've tried checking the overlapping named sections, there are none, but still getting the same error. Â
January 31, 2024 at 1:12 pm
V.P
Ansys EmployeeHi Prashant,
Can you try this, open the mesh editor, right-click on Mesh in the outline tree, and Click on Update. Check for the warning message, which might give a more clear idea of what might be the issue.
- The topic ‘Update failed for mesh component in Fluid flow (Fluent).’ is closed to new replies.
5944
1307
