July 27, 2021 at 4:26 am
skaehne
SubscriberHi all,
I am trying to simulate ice accretion on a Vertical Axis Wind Turbine (specifically a Savonius turbine) when it is both stationary and rotating. The stationary simulations work well and provide useful results. Unfortunately, when I try and set the turbine walls to rotating, I get an 'unsupported topology' error. I wonder if anyone has had a similar issue or known how to fix this?
Thanks.
July 31, 2021 at 5:04 amJian Chen
Ansys Employeehi, Skaehne
if possible, it's better to introduce your case to us with the following infor.:
which version you are using to simulate in your case?
how does your computational domain look like? your turbine is placed inside a tunnel or with a farfield boundary? in your grid/mesh, does it contains only one domain, or more than one? (it would be nice to have a figure to show us your case roughly.)
which module you are using, the FENSAP or FENSAP-TURBO?
Thanks.
August 2, 2021 at 1:13 amskaehne
SubscriberHi JianChen Thanks for responding. I am using FENSAP 2021 R1 to simulate and I am using just FENSAP not FENSAP-TURBO. My domain is shown in the attached image - I have placed the turbine in a relatively large 'tunnel' with a frozen smaller refinement domain (white box outline) to allow for a more refined mesh closer to the turbine.
(I've hidden the inlet and outlet to view the domain easier)
Any help is greatly appreciated
Cheers.
August 12, 2021 at 10:51 pmJian Chen
Ansys Employeehi, Skaehne v2021 R1 doesn't support setting rotational wall in a stational (frame) simulation with a non-periodic mesh/grid. But this has been currently supported in v2021 R2 as a beta feature.
Therefore, please use v2021 R2 to set up your case.
Thanks.
Viewing 3 reply threads- The topic ‘Unsupported topology error for rotating wall in FENSAP-ICE’ is closed to new replies.
5964
1307
