May 20, 2021 at 1:07 pm
feroz.mulani85
SubscriberI am trying to simulate Rayleigh-benard convection problem using Boussinesqs approximation, in a square cavity,
Top surface is cold, bottom is hot, side walls are adiabatic, using water as fluid.
In general it is said that natural convection problems are unsteady.
In some papers which i have referred the authors used steady formulation to solve the problem while in some papers the authors used transient formulation during simulation. SO i am confused, whether to use steady or transient formulation.
Please help.
May 20, 2021 at 1:53 pmRob
Forum ModeratorYes, either can and do work. It depends what you're wanting to see.
Viewing 1 reply thread- The topic ‘Unsteady formulation for natural convection’ is closed to new replies.
Ansys Innovation SpaceTrending discussions- air flow in and out of computer case
- affinity not set
Top Contributors-
3862
1414
1231
1118
1015
Ansys Assistant
Welcome to Ansys Assistant!
RETRY
