March 5, 2024 at 5:14 pm
21642478
SubscriberHi,
I have been setting up a MBD simulation for a vibration isolation problem but I have encountered an unspecified global damping. As can be seen in the screenshot below, the damping assigned to the spring is zero but the simulation exhibits damping. I would like to have the simulated system to behave as the analytical system. Is there a certain global damping parameter that I can set?
The simulation was set up using the standalone motion preprocessor.
Christo
March 6, 2024 at 7:40 am
ErKo
Ansys EmployeeHi
We will get back to you on that.
Thanks
Erik
March 6, 2024 at 8:39 am
March 6, 2024 at 10:41 am
21642478
SubscriberHi,
It solved the problem.
Thanks.
March 6, 2024 at 11:12 am
ErKo
Ansys EmployeeGreat - closing as others might encounter the same.
Erik
Viewing 4 reply threads
- The topic ‘Unknown Global Damping – Ansys Motion’ is closed to new replies.
1535
1386
1215
