April 20, 2024 at 5:28 pm
matthew.fig
SubscriberI am simulating the crushing of an aluminum cylinder using Mechanical and a multilinear model. I got to the point where needed to try adaptive meshing due to large deformation, so I activated the nonlinear remeshing model. The first time that Mechanical remeshes, I get an "Unknown error" message. Here is the relevant section of the solver output. I searched online for anywhere that the message found in the output has been seen before, and I had no luck. Can anyone tell me what happened and how to fix it? I am using tetrahedral elements.
Thanks
 **** REGENERATE MESH AT SUBSTEP 1430 OF LOAD STEP     1 BECAUSE OF
     NONLINEAR ADAPTIVE CRITERIA
     PREPARING DATA TO REMESH......
     REMESHING REGIONS ARE CREATED; GENERATING NEW MESH......
 AmsMesher(ANSYS Mechanical Solver Mesher),Graph based ANSYS Meshing EXtension,v
 1.35.06f
 (c)ANSYS,Inc. v241-20230804
  Platform          : Windows 10.0.22621 AmsMesher
 - 12:0:12 2024-4-20 AmsMesher started...
  == Mesh quality metrics comparison [ EType 285 ]
  Element Average   : ------Source/32894-----+------Target/44436----
  ..Skewness(Vol)   :   0.4666                  0.2436            Â
  ..Aspect Ratio    :   2.4440                  1.8848            Â
  Domain Volume     : 1.0562e-07              1.0548e-07          Â
  Worst Element     : --------Source--------+--------Target--------
  ..Skewness(Vol)   :   0.9666 (e4495   )     0.8494 (e81110  )  Â
  ..Aspect Ratio    :  20.7607 (e13696  )    12.6873 (e91729  )  Â
  == Remeshing result statistics                                   Â
  Domain(s)         :  1     Â
  Region(s)         :  1     Â
  Patch(es)         :  9     Â
  nNod[New]         :  11729      Â
  nElm[New/Ef/Sd/Sr] :  44436 / 32894 / 7248 / 33152     Â
  Peak memory       :  132 MB AmsMesher
 - 12:0:17 2024-4-20 AmsMesher finished..
 - AmsMesher run completed in 4.115 seconds
  ========================= End Run =================================
 *** ERROR ***                          CP =   3173.672  TIME= 12:00:24
 New nodal normal was not correctly computed for node 16213 of face    Â
 16729 while doing Nonlinear Adaptivity.                               Â
 16730 while doing Nonlinear Adaptivity.                               Â
 *** ERROR ***                          CP =   3173.703  TIME= 12:00:24
 *** ERROR ***                          CP =   3175.109  TIME= 12:00:29
 **** FAILED IN NEW MESH GENERATION! PLEASE CHECK THE ERROR FILE FOR DETAILS.
 *** ERROR ***                          CP =   3176.094  TIME= 12:00:31
 Unexpected error was encountered in NlAdptStartRun.F. Please send theÂ
 data leading to this operation to your technical support provider, as Â
 this will allow ANSYS, Inc to improve the program.                    Â
 NUMBER OF WARNING MESSAGES ENCOUNTERED=      1359
 NUMBER OF ERROR  MESSAGES ENCOUNTERED=        13 -
April 23, 2024 at 8:38 am
Aurojyoti Prusty
Ansys EmployeeHello,
The large deformation problems tend to distort the element which leads to convergence issues and that might be the reason why it is showing the error. Does the model involve alluminium with any type of rubber? You can try with hex elements if the geometry is not too complicated and go for tet element for little complex geometry parts. You can refer the below video to know how to handle Element Distortion Errors in Hyperelastic Material.
https://www.youtube.com/watch?v=fI2a_xP0veI&t=33s
Similar discussion below on why NLAD does not resolve issue if it involves plasticity.
Please let us know.
Thanks,
Aurojyoti
- The topic ‘Unknown error occured during nonlinear analysis’ is closed to new replies.
