Unknown error in modal analysis
    • baswaraj123
      Respected sir
      I am doing modal analysis on engine block.
      mesh is generated properly but when i request for output it is giving me error.
      " An unknown error occurred during solution.  Check the Solver Output on the Solution Information object for possible causes."
      please help me to solve this problem.
      How should i upload file of ansys?
    • tsiriaks
      I'd recommend to post this under Physics Simulation  ->  Structural Mechanics  section.
      Thanks,
      Win
    • baswaraj123
      solution outputyes sir i have posted this under Physics Simulation  ->  Structural Mechanics  section.
      @Win, looking at the screen shot, this ANSYS 19.2 Student license has a licensing issue, it is trying to obtain a Mechanical Enterprise license from a license server.
      @baswaraj123,  Is there a reason you need Release 19.2?  If not, you could try installing ANSYS Student 2019 R2 and see if you can run your model there. Note that if you save your model in 2019 R2, you won't be able to open those files in 19.2, so create an archive of the model in 19.2 and put that file aside before you install 2019 R2.
  • The topic ‘Unknown error in modal analysis’ is closed to new replies.
