November 29, 2024 at 12:21 pm
gambra77
Subscriberhi everyone, i tried simulating one mechanism that i ran a week ago but changing some parametres and doesn´t work.
Anyone knows why?
Ansys Mechanical Enterprise Academic Student    Â
 ANSYS LICENSE MANAGER ERROR:
 Insufficient FlexNet Publisher (FNP) license count of HPC Parallel are available for use, only 2 of the requested 4 tasks were available.
 No FlexNet Publisher (FNP) license found for feature HPC Parallel.
            FNP license path: C:\Users\gambr\AppData\Local\Temp\\2b4fb129-cada-492e-933b-2dd5ba1bf98a
 *** ERROR - Insufficient HPC licenses available.
whybad=Â Â Â Â Â Â Â Â Â -5
+--------------------- M A P D LÂ Â S T A T I S T I C S ------------------------+
Release: 2024 R2Â Â Â Â Â Â Â Â Â Â Â Build: 24.2Â Â Â Â Â Â Update: UP20240513Â Â Platform: WINDOWS x64
Date Run: 11/29/2024Â Â Time: 13:17Â Â Â Â Process ID: 13244
Operating System: Windows 11Â (Build: 22631)
Processor Model: 12th Gen Intel(R) Core(TM) i5-12450H
Compiler: Intel(R) Fortran Compiler Classic Version 2021.9Â (Build: 20230302)
         Intel(R) C/C++ Compiler Classic Version 2021.9 (Build: 20230302)
         Intel(R) oneAPI Math Kernel Library Version 2023.1-Product Build 20230303
Number of machines requested           :   1
Total number of cores available        :  12
Number of physical cores available     :   8
Number of processes requested          :   4
Number of threads per process requested :Â Â Â 1
Total number of cores requested        :   4 (Distributed Memory Parallel)             Â
MPI Type: INTELMPI
MPI Version: Intel(R) MPI Library 2021.11 for Windows* OS
GPU Acceleration: Not Requested
Job Name: file0
 Core               Machine Name  Working Directory
    0                    PCAITOR  C:\Users\gambr\AppData\Local\Temp\WB_gambr_21260_10\_ProjectScratch\Scr7F1C
    1                    PCAITOR  C:\Users\gambr\AppData\Local\Temp\WB_gambr_21260_10\_ProjectScratch\Scr7F1C
    2                    PCAITOR  C:\Users\gambr\AppData\Local\Temp\WB_gambr_21260_10\_ProjectScratch\Scr7F1C
    3                    PCAITOR  C:\Users\gambr\AppData\Local\Temp\WB_gambr_21260_10\_ProjectScratch\Scr7F1C
Total CPU time for main thread                   :       0.1 seconds
Total CPU time summed for all threads            :       0.0 seconds
Elapsed time spent obtaining a license           :       0.5 seconds
Elapsed time spent pre-processing model (/PREP7)Â :Â Â Â Â Â Â Â 0.0 seconds
Elapsed time spent solution - preprocessing      :       0.0 seconds
Elapsed time spent computing solution            :       0.0 seconds
Elapsed time spent solution - postprocessing     :       0.0 seconds
Elapsed time spent post-processing model (/POST1) :Â Â Â Â Â Â Â 0.0 seconds
Sum of disk space used on all processes          :       0.0 MB
Sum of memory used on all processes              :       8.0 MB
Sum of memory allocated on all processes         :       0.0 MB
Physical memory available                        :        16 GB
Total amount of I/O written to disk              :       0.0 GB
Total amount of I/O read from disk               :       0.0 GB
+------------------ E N DÂ Â M A P D LÂ Â S T A T I S T I C S -------------------+
 |                              RUN COMPLETED                                |
 | Ansys MAPDL 2024 R2        Build 24.2        UP20240513   WINDOWS x64  |
 | Database Requested(-db)    1024 MB    Scratch Memory Requested     0 MB |
 | Max Database Used(Master)     1 MB    Max Scratch Used(Master)     1 MB |
 | Max Database Used(Workers)    1 MB    Max Scratch Used(Workers)    1 MB |
 | Sum Database Used(All)        4 MB    Sum Scratch Used(All)        4 MB |
 |       CP Time     (sec) =         0.047      Time = 13:17:21         |
 |       Elapsed Time (sec) =         1.000      Date = 11/29/2024       |
 -----------------------------------------------------------------------------Â
thanks Aitor
December 2, 2024 at 8:39 am
Rajeshwari Jadhav
Forum ModeratorHi,
According to error you don't have sufficient HPC licenses, please decrease the no. of cores and try again.
December 2, 2024 at 9:44 am
gambra77
SubscriberThanks, it worked!
5969
1307
