January 8, 2022 at 6:00 pm
camasmie
SubscriberI have the following versions of ANSYS on my machine, but for some reason, I don't have the uninstall files for it:
ANSYS v212, and ANSYS Student v191, and v194
Is it possible to download these uninstallers from your website?
Thanks
January 9, 2022 at 1:38 pm
Charudatta Bandgar
Forum ModeratorHello Paulo Camasmie
Let me check if I can find them.
In the mean time, try copy pasting new version uninstall file, and see if it works. Sometimes it does. The uninstall executable can also be found in C:Program FilesANSYS Incv__ Run uninstall.exe. If it is not present there, copy paste and see.Â
Also, I assume you are not referring to discovery products, In that case I would suggest you please post it on ANSYS Customer Portal or Ansys Learning Forum based on the type of license that you have. This ANSYS Discovery Community Forum is intended for seeking help on ANSYS Discovery products. Thank you for your understanding!
Regards.
- The topic ‘Uninstalling older versions’ is closed to new replies.
- Unable to attach geometry 2024 R2
- Data Center Simulation
- [SpaceClaim] STEP file size using Converter.exe
- How to do the snap fit insertion FEA?
- Spaceclaim 2024 error FNE activation failed
- PMI Product manufacturing information in SpaceClaim/Discovery modeling
- PlugIn Error: Failed to import assembly from SpaceClaim. The object is deleted.
2979
970
857
755
599
