June 5, 2024 at 5:19 pm
deepesh.p.gurdasani
SubscriberHow to apply UDL and UVL on a 3D body ?
Thanks in advance
July 4, 2024 at 6:06 pm
deepesh.p.gurdasani
SubscriberAny suggestions on this?Â
Thanks in advance
July 5, 2024 at 11:15 am
peteroznewman
SubscriberIf you have a solid cube and apply a Pressure to one face, that will be a Uniformly Distributed load.
In the Pressure Details window, in the Tabular Data section, there is an Independent Variable. Change that from Time to the Y axis. Now you will be able to type in the starting pressure and the ending pressure as a function of the Y coordinate, which is a Uniformly Varying load.
July 12, 2024 at 1:34 pm
deepesh.p.gurdasani
SubscriberSir, can you reverify regarding 'y axis' option in latets versions because I couldnt find that option.Â
Thanks
July 9, 2024 at 7:04 pm
deepesh.p.gurdasani
SubscriberI think changing it to 'Y axis' option is not there in versions post 2022 R1. Any other way to apply varying load w.r.t length?Â
July 9, 2024 at 7:07 pm
deepesh.p.gurdasani
SubscriberI think changing it to 'Y aixs' option is not there after 2022 R1 versions.Â
July 10, 2024 at 4:17 pm
deepesh.p.gurdasani
SubscriberAny suggestions are welcome.
Thanks in advance
- The topic ‘Uniformly Distributed load and Uniformly varying load’ is closed to new replies.
5834
