May 8, 2019 at 11:08 am
APRU0707
SubscriberHello everyone,
I have a problem with meshing my cylinder (quarter of a cylinder) with hole at the centre. For analysis purpose, I need a uniform mesh with rectangular cross-section. My model is a 3D one and I used volume for model creation. I am confusion right from the element selection to the way meshing is to be done.
Can anyone help me with the same.
APRU0707
May 20, 2019 at 8:51 am
Rohith Patchigolla
Ansys EmployeeHello APRU0707,
Did you try using sweep method?
Here is a simple example using the sweep method to create the mesh on a quarter cylinder.Â
fini
/clear,nostart
/prep7
et,1,186 !create a new structural element typeÂ
mp,ex,1,2e5 !create material data
mp,prxy,1,0.3
cyl4, , ,5,0,7,90,10 !create a quarter cylinder
extopt,vswe,auto,0Â !Specify source and target surface for sweep
extopt,esize,3 !specify number of divisions
vsweep,1,4,3 !sweep with source area as Area#4 and target area as Area#3
Hope this helps. Please have a look at the help doc for further reference on the commands. You can also do this workflow via GUI
Best regards,
Rohith
- The topic ‘Uniform meshing in APDL’ is closed to new replies.
Ansys Innovation Space
1414
1256
1118
1015
