November 26, 2024 at 7:17 pm
javat33489
SubscriberHello everyone.
I am calculating rubber in LS-Dyna ACT Workbench.If I use standard rubber from the database: Elastomer Ogden 3, then everything is solved. If I use my rubber, with uniaxial tension (I have test data) and Ogden 1 then I get the following errors:
For the test, I also tried to remove data from the standard Elastomer Ogden 3 except for uniaxial tension and added Ogden 1, there are also errors.
Why? What should I do to make it work?
Thanks.
November 27, 2024 at 1:24 pm
Ram Gopisetti
Ansys EmployeeHi,Â
How stiff is your tested material? Have you tested with tet elements? If so, can you post your results?Â
Cheers, RamÂ
November 29, 2024 at 5:28 pm
