June 29, 2025 at 9:41 pm
Jmseele
SubscriberI am running a fluent simulation and get the message:Â
iter continuity x-velocity y-velocity z-velocity energy time/iter
Stabilizing temperature to enhance linear solver robustness.
Stabilizing temperature using GMRES to enhance linear solver robustness.
Divergence detected in AMG solver: temperature
Error at host: floating point exception
===============Message from the Cortex Process================================
Compute processes interrupted. Processing can be resumed.
Error at Node 0: floating point exception
Error: floating point exception
Error Object: #f
My mesh orthogonal quality is good and I can not find anything specific about the cause of error when running a mesh check. Can anybody help?
June 30, 2025 at 7:31 am
Forum ModeratorWhat models, materials and boundary conditions are you using?Â
June 30, 2025 at 10:31 am
Jmseele
SubscriberI am using laminar flow and energy model. My BCs are inlet velocity and pressure outlet with reverse flow prevented. Using propylene glycol/water mixture for fluid zones and copper aluminum steel for solid zones. I also have a heat generation source
June 30, 2025 at 10:34 am
Forum ModeratorOK, and what sort of temperatures are you expecting? The energy equation looks to have failed first, so start with the source term. What is the fluid density modelled as? Has it run any iterations or has the solver failed on the first iteration?
June 30, 2025 at 8:58 pm
Jmseele
SubscriberI'm expecting temperatures from 11-40 deg C. fluid density is constant 1085 kg/m^3. Fails on the first iteration.
July 1, 2025 at 8:42 am
Forum ModeratorOK. Turn off the source term and run 10 iterations. How does the flow look? Save case & data. Turn on the source term, run 10 iterations.Â
3402
1052
1050
886
857
