Unexpected High-Speed Flow in ANSYS 24.0 Compared to 17.2
    • luna6362
      Hello everyone,
      I am currently simulating a compressor which includes a rotating rotor using the MRF method. Previously, I used version 17.2 for the simulation and the flow field appeared normal. However, with the same settings, the simulation results in version 24 are very strange. There is a significant high-speed flow on the walls, which I believe is not a normal simulation result. Below are my settings. Are there significant differences between version 17 and version 24 for these settings?
      Mesh:
      • Meshing Element size: 0.8mm
      • Face sizing to MRF area: 0.6mm
      Fluent setting:
      • Steady
      • Reynolds stress model
      • Frame motion Y = 1, -4850 rev/min
      Material:
      • R32
      • Density: 61.5295 kg/m³
      • Viscosity: 1.5923e-05 kg/ms
      Boundary conditions:
      • Mass Flow inlet: 0.01353 kg/s
      • Pressure outlet: 2824315 Pa
      Method:
      • Coupled
      Thank you!
    • Essence
      Yes, there have been significant improvements in the code since 17.2 version. Please look for viscous models, methods, controls and the materials section.
