July 3, 2024 at 7:41 pm
luc.bernhardt
SubscriberHi, I'm having some problems solving a static structure simulation.Â
I'm using ANSYS Student on a Macbook Pro with an M1 Pro chip via Parallels VM. I used this video to install it:
?si=EnaYI38bHPFxT0v7. Workbench and Mechanical work fine but as soon as I want to solve a simulation, this error occurs: Â
"*** ERROR *** Â Â Â Â Â Â Â Â Â Â Â Â Â CP = Â Â Â 0.812 Â TIME= 17:33:52
 An unexpected error ( SIG$ILL ) has occurred...  MAPDL internal data  Â
 has been corrupted.  MAPDL is unable to recover and will terminate.   Â
 Previously saved files are unaffected.  Please send the data leading  Â
 to this operation to your technical support provider, as this will   Â
 allow ANSYS, Inc to improve the program."ÂI checked the memory, GPU and processor settings as in other forum threads. I have the latest ANSYS Student R1 version, downloaded on June 23. However, nothing seems to work in my case. What should I do to solve this problem? Has anyone encountered this problem before?Â
July 4, 2024 at 10:16 am
Forum ModeratorThe various Windows emulators work/fail as patches and software are updated. So you may find updating the OS & drivers to help, also check on here as it's a question that comes up on occasion. The Ansys tools are built for Windows (Full & Student versions) and some flavours of Linux/UNIX (Full version) but may work on unsupported platforms. However as the solvers use a few less common libraries and functions their use can be less successful than running PC games on a Mac.Â
- The topic ‘Unexpected error – Static structure simulation’ is closed to new replies.
4127
1487
1318
1158
