Preprocessing
Preprocessing
uncovered face
    • valentina
      Hi everyone! I have a problem with the mesh generation. Below there is attached a picture and as you can see, there is an area with mesh in between 2 blocks. I tried everything like merge vertices, check and delete the elements which are over there, but in the pre-processing it appears as a default boundary condition and it gives me an error when I want to run the simulation. I am wondering if there is any way to solve this to avoid making again the blocks from the entire domain. Thanks!
    • Keyur Kanade
      When you say there is mesh between two blocks means you have already converted it to unstructured mesh?
      Can you please explain full procedure.
    • valentina
      I discovered the problem. But ansys is very strange. For example, if you pre-mesh and then suddenly you want to split a block and create a point or a line in order to assign the edge or vertex, then in pre-solver will show you as an extra boundary condition and you cannot remove it.
    • Keyur Kanade
      Can you please try 'Recompute' on premesh?
      Can you please try Blocking - PreMesh Param - Update All?
    • Keyur Kanade
      Also as it is solved, can you please mark it as Is Solution to help others on forum.
    • Sidharath
      Hi
      I want to ask a question on student forum but i am unable to ask it. My question is below.
      i am new to icemcfd. i am getting this error volume elements  were found for Uncovered faces. I will try to explain my procedure. please help me out.
      -I imported my geometry and named the surfaces like inlet, outlet
      - i created a block and further split it.
      - on some blocks i required a coarse mesh so made them free blocks and did mesh refinemnt 1/3.
      -i did pre mesh and the convert it to uns.mesh
      - i have some hangiong nodes in order to fix it i did merge node then resolve refinement.
      - when i go to check mesh i got this error
Viewing 5 reply threads
  • The topic ‘uncovered face’ is closed to new replies.
