April 25, 2019 at 5:41 am
Rania
Subscriber Hi
my model consist of steel plate connected with four steel pipe (same material). the plate is connected to the sleeves or /small pipe through rigid connection)
the connection between the sleeves (in the plate) and the pipe is through screw and friction on one side (not there is a gap between the sleeves in the plate and the steel pipes)
element type chosen as solid 183 for the pipe, plate and screw
contact pairs: between the screws and the pipes (frictional=0.2)
the error after running the solution is "unconverged solution"
I appreciate any help or suggestions to improve the model
April 25, 2019 at 8:44 am
jj77
SubscriberVery difficult to help if we do not have more details. So explain your model and what you are trying to achieve, post some screenshots of your settings (contacts, solution,..), and finally some more info about the convergence problem. Also if you can attach your model using the attach button on your first post and then using a .wbpz archive format which you can generate from WB by going to the main menu and File and Archive.
- The topic ‘UNCONVERGED SOLUTION’ is closed to new replies.
5074
1798
1387
1248
