Electronics
Electronics
Unable to temperature variations in Ansys as a result of loses from Maxwell
    • NuelWeta
      Good morning all.
      I modeled my motor in maxwell, got the necessary losses. The analysis is on no load condition. I exported the model to Ansys for thermal analysis and applied a convective boundary condition on all the 68 edges of the model
    • Karthik Remella
      Administrator
      Hello,nOnce you export the load from Maxwell, what does it look like when you read this into Steady-State Thermal? Can you plot just the 'Imported Heat Generation' Load and post the contour here? Do these values compare with what you are seeing in Maxwell?nKarthiknn
  • The topic ‘Unable to temperature variations in Ansys as a result of loses from Maxwell’ is closed to new replies.
