Unable to start the mechanical and geometry editor in Ansys workbench 14.5
    • Joseph Lim
      Dear community,
      Attached is the error that I encounter when I start to open the mechanical and geometry editor. May I ask for some suggestions and help with those problems?
      Thank you very much in advance.
      Joseph
      Is the problem you are asking about that there are no tools in the toolbox?
      For the toolbox issue, I assume you have tried a restart on your computer.
      Is the license local to that machine or is there a license server that machine needs to communicate with?
    • Joseph Lim
      Hello Peter,
      Yes, I have a problem with the toolbox issue. I have tried to restart on my computer numbers of times but I still have the similar problem.
      I think is a license server that machine needs to communicate with.
      Joseph
    • Bhargava Sista
      Joseph,
      Try these steps:
      • Close all open WB sessions.
      • In Run, type %appdata%, this will open the Roaming folder. Open the folder named Ansys.
      • Since you're using version 14.5, look for a folder named v145. Rename it as v145_old.
      • Now open a new WB session, see if this resolves the issue.
      Let us know if that helps, cheers!
    • Joseph Lim
      Hi Bsista,
      Thanks for the suggestion. I had tried using other approaches which I reinstall the software (Ansys Workbench 14.5). The problems solved after I reinstall the software.
      Cheers!
      Joseph
    • Tarek20
      Hello every onennI am facing a problem related to open a new design modeler while clicking on Geometry it shows the following message as shown in the picture . nn
Viewing 5 reply threads
  • The topic ‘Unable to start the mechanical and geometry editor in Ansys workbench 14.5’ is closed to new replies.
