December 5, 2024 at 1:23 am
S A
SubscriberHello,
I am trying to run a Eulerian DDPM, however, in the boundary conditions, I would like to set an outlet using mass-flow outlet, but I keep getting a message that this type of outlet is not possible while using DDPM.
May I please ask why and if there is an alternative way to do that? the outlet is an important parameter in the simulation.
Thank you very much!
December 5, 2024 at 11:41 am
Forum ModeratorDDPM uses the Eulerian Multiphase model and that means no mass flow outlet. What level of volume loading have you got as DPM may be sufficient?
December 6, 2024 at 4:29 pm
S A
SubscriberHi Rob!
Thank you for your reply!
I'm doing a fume hood simulation within a room. Theres a duct inlet, duct outlet for the room and a fume hood outlet. I'm trying to siumulate air and particles, so I am using Eulerian, DDPM, with 1 Eulerian phase and 1 discrete phase.
Thank you!
December 9, 2024 at 11:29 am
Forum ModeratorIf you're pushing over about 12% volume of particles out of a fume cupboard you have a much more serious problem with whatever you're playing with! I've only ever used DPM for fume cupboards, so I'd review your choices to make sure you REALLY need DDPM.Â
December 9, 2024 at 5:12 pm
S A
SubscriberThank you Rob!
The plan was to use DPM but I am unable to add a discrete phase unless I enable DDPM.
How may I use particles in fume hoods using DPM, if I may ask you, please?
Thank you so much!
December 9, 2024 at 5:21 pm
Forum ModeratorThe word you're looking for is "Injection". You inject particles from somewhere (often an inlet but other options exist) which then follow and maybe influence the flow.Â
December 9, 2024 at 5:29 pm
S A
That is what I thought but I wasn't sure I can do that while Eulerian was disabled.
Thank you very much for your time and help!
December 9, 2024 at 5:33 pm
Forum ModeratorEulerian isn't DPM but the DDPM model uses elements of both. I tend to use one or other of Eulerian or DPM, it's rare that I'd use DDPM.Â
December 9, 2024 at 5:37 pm
S A
SubscriberThank you for all your help!
5799
