July 16, 2023 at 5:50 pm
Mark P
SubscriberHi, I've just started learning ANSYS for simulation purposes. I'm experienced in Solidworks, so I imported a part from Solidworks using an .IGS file.ÂAfter applying the meshing, I proceeded to apply the loads, and that's where the problems began. I decided to apply a bearing load and two cylindrical supports. To do this, I need to select cylindrical surfaces. These surfaces are present in my imported model.ÂHowever, both ANSYS Mechanical and ANSYS Design Modeler recognize the holes as two half-cylinders instead of cylinders. As a result, in ANSYS Mechanical, I am unable to select these holes as the geometry for the bearing load and cylindrical supports.ÂI tried merging two of these half-cylinders in Design Modeler, which visually solved the problem. However, I still couldn't select these surfaces for load application.ÂThank you in advance for your help. Cheers! -
July 16, 2023 at 8:40 pm
peteroznewman
Subscriber- IGES is a poor choice for moving solid models from SolidWorks to Ansys. Use Parasolid instead.
- Open the geometry in SpaceClaim and on the Repair tab, click the Extra Edges button then the Split Edges button. Try the Simplify button.
July 17, 2023 at 10:46 am
Mark P
SubscriberThank you, using parasolid file type worked!
- The topic ‘Unable to select a cylinder in an imported geometry (from Solidworks)’ is closed to new replies.
1500
1386
1209
