TAGGED: #fluent-#ansys, #fluent-#cfd-#ansys, fluent-mesh
September 28, 2022 at 2:16 am
Love Bista
SubscriberI am a beginner..i imported my model on design modeler and tried to create a mesh but cannot see the model in mesh edit mode..I have intel(R) HD Graphics 620 display adapter in windows 10. I have set high performance graphics for work bench app. Please advice any solution..
September 28, 2022 at 5:39 am
Keyur Kanade
Ansys EmployeePlease create a small box in DM and check.Â
Please check followign link for supported platforms.Â
Platform Support and Recommendations | Ansys
Keyur
September 28, 2022 at 8:37 am
Forum ModeratorAlso, please post some images. "Can't see" can be caused by an import failure, meshing failure, unsuitable graphics hardware or you missed a display button somewhere!Â
September 28, 2022 at 11:54 am
Love Bista
Subscriberdear team,
Thank you for the reply,
I created a ox on DM and opened the mesh editor. The box appeared in the mesh editor when i double clicked the mesh component after refresing . But still unable to see my project model in mesh editor. I have attached the images of both sample Box geometry and my college project model.
September 28, 2022 at 2:46 pm
Love Bista
Subscriberfinally able to view the model. set both workbench and solid works on high performance graphics. restarted the project and finally got the model on mesh editor...Cheers team
September 28, 2022 at 3:43 pm
Forum ModeratorIn other words, you've got a very thin domain relative to the length. Given you have a 512k cell limit, need 10-ish cells across the pipe diameter for CFD (absolute minimum) and an aspect ratio of 3-5 how many cells do you reckon you'll finish up with?Â
September 29, 2022 at 5:38 pm
Love Bista
SubscriberI am doing meshing in only one bore. Can you suggest if i can create infation for meshing as the diameter of pipe is smaller conpared to the far ground radious.
September 30, 2022 at 4:41 am
Keyur Kanade
Ansys EmployeeHello, can you please create another post for different question.Â
- The topic ‘Unable to see the model in mesh edit mode’ is closed to new replies.
- affinity not set
4092
1487
1318
1156
