April 2, 2024 at 9:11 pm
Luis Rodriguez
SubscriberHello all,Â
I am trying to export time step data of the results from a explicit dynamics simulation that I completed. I wanted to evaluate the time step date within the .rst file but when looking in the solver files directory, there is no .rst file. In addition, when clicking on the solution tab, the "Write Input File" appears gray and as well as the "Read Result Files."
What could I do to be able to retrieve the .rst files from the simulation generated?
Thank you in advance for the assistance.Best,
Luis Rodriguez -
April 3, 2024 at 2:30 pm
Ram Gopisetti
Ansys EmployeeHi Luis,Â
If you talk about the explicit dynamics, the solutions are given in the admodel_xx.adres files , on reading and writing the files into the system its currently blocked by an XML tag at backend and this might be changed in the newer versions,Â
Cheers, RamÂ
April 8, 2024 at 7:15 pm
Luis Rodriguez
SubscriberHi Ram,Â
Thank you for sharing this information, I did not know that the result files are given as .adres.Â
I appreciate the assistance!
Best, Luis Rodriguez
- The topic ‘Unable to see .rst files in Solver Files Directory’ is closed to new replies.
5814
