October 27, 2021 at 5:53 pm
kindires
SubscriberHello,
We have Lumerical Academic license. I understand this allows us to use up to 128 distributed cores (4*32). I am currently trying out a problem using FDTD and every time I submit a job to the cluster, I get licensing error (details below). I have successfully run Lumerical FDTD on the same cluster via GUI. I would like to advise users to make use all licensed capabilities to solve a larger problem.
First trying out with a single core and single node:
.../mpich2/nemesis/bin/mpiexec -n 1 fdtd-engine-mpich2nem -t 1 -fullinfo test_mpi_nano_scatter.fsp
Edited output (I have taken out site specific info. The message shows the right license path):
...(process 0): Failover feature 'Ansys Lumerical Enterprise Solver' is not available.
Request name lumerical_solve does not exist in the licensing pool.
No such feature exists.
Feature:Â Â Â Â lumerical_solve
License path: [email protected]<...>
FlexNet Licensing error:...(process 0): Error: Failed to checkout feature 'lumerical_solve'
Thanks
October 27, 2021 at 6:15 pmLito
Ansys EmployeeTry to set the license server information on the cluster without the GUI as shown here.
October 27, 2021 at 9:10 pmkindires
SubscriberHello Ok, we were already setting the ANSYSLMD_LICENSE_FILE variable when we loaded the Lumerical module. I found out that I had a License.ini file with the wrong domain number (0 instead of 2).
The hint came from the reference to Ansys Enterprise solver in the error message!
BTW, the page you reference also says License.ini settings take precedence over ANSYL_LICENSE_FILE variable. It was clearly a mistake on my part.
Thanks again for your help.
October 27, 2021 at 9:17 pmLito
Ansys Employee,You are welcome. Glad to hear it's working.Viewing 3 reply threads- The topic ‘Unable to run mpi jobs on a cluster’ is closed to new replies.
5884
1306
