August 16, 2023 at 8:49 am
Cristina Teleanu
SubscriberI am trying to run the LS-DYNA heart valve tutorial on the HPC, using MPI. It runs for about 10 seconds and then I get an Error Termination with the below error message:
   ___________________________________________________Â
   |  LS-DYNA, A Program for Nonlinear Dynamic     |
   |  Analysis of Structures in Three Dimensions    |
   |  Date   : 03/10/2022   Time: 06:59:30      |
   |  Version : mpp d R13                |
   |  Revision: R13.1-138-g8429c8a10f          |
   |  Features enabled in this version:         |
   |   Distributed Memory Parallel           |
   |   CESE CHEMISTRY EM ICFD STOCHASTIC_PARTICLES   |
   |   FFTW (multi-dimensional FFTW Library)      |
   |   ANSYSLIC enabled                |
   |  Licensed to:                   |
   |  Platform  : Intel-MPI 2018 Xeon64        |
   |  OS Level  : Linux CentOS 7.8 uum         |
   |  Compiler  : Intel Fortran Compiler 19.0 AVX-2  |
   |  Hostname  : d8s3b3.arc4.leeds.ac.uk       |
   |  Precision  : Double precision (I8R8)       |
   |  Unauthorized use infringes Ansys Inc. copyrights |
   |___________________________________________________|Messages file /ansys_inc/shared_files/licensing/language/en-us/ansysli_msgs.xml does not exist.
[license/info] Successfully checked out 1 of "dyna".
[license/info] --> Checkout ID: d8s3b3_arc4_leeds_ac_uk-scct-215201-000002(days left: -1)
[license/info] Successfully checked out 11 of "FEAT_DYSMP".
[license/info] --> Checkout ID: d8s3b3_arc4_leeds_ac_uk-scct-215201-000009(days left: -1)
[license/info] Successfully started "ANSYS_LSDYNA".
 *** Error 70022 (OTH+22)
   Please file a Service Request (SR) via the ANSYS Customer
   Portal at https://support.ansys.com.
   Customers using an academic license may seek assistance
   at https://forum.ansys.com
 E r r o r  t e r m i n a t i o n===================================================================================
= Â BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
= Â RANK 0 PID 214872 RUNNING AT d8s3b3.arc4.leeds.ac.uk
= Â KILLED BY SIGNAL: 9 (Killed)
= Â RANK 1 PID 214873 RUNNING AT d8s3b3.arc4.leeds.ac.uk
= Â KILLED BY SIGNAL: 12 (User defined signal 2)
= Â RANK 2 PID 214874 RUNNING AT d8s3b3.arc4.leeds.ac.uk
= Â RANK 3 PID 214875 RUNNING AT d8s3b3.arc4.leeds.ac.uk
= Â RANK 4 PID 214876 RUNNING AT d8s3b3.arc4.leeds.ac.uk
= Â RANK 5 PID 214877 RUNNING AT d8s3b3.arc4.leeds.ac.uk
= Â RANK 6 PID 214878 RUNNING AT d8s3b3.arc4.leeds.ac.uk
= Â RANK 7 PID 214879 RUNNING AT d8s3b3.arc4.leeds.ac.uk
= Â RANK 8 PID 214880 RUNNING AT d8s3b3.arc4.leeds.ac.uk
= Â RANK 9 PID 214881 RUNNING AT d8s3b3.arc4.leeds.ac.uk
= Â RANK 10 PID 214882 RUNNING AT d8s3b3.arc4.leeds.ac.uk
= Â RANK 11 PID 214883 RUNNING AT d8s3b3.arc4.leeds.ac.uk
I am using Ansys licensing but had installed LS-DYNA R13.1.0 separately as the HPC only had the R11 version available. Â
Could you please advice? -
August 17, 2023 at 3:43 pm
Ram Gopisetti
Ansys EmployeeHi,
based on your last statement, I guess you need to have a license to add in the keys for R13 and higher,Â
does the same behavior happen using R11?
Cheers, RamÂ
- The topic ‘Unable to run LS-DYNA simulation’ is closed to new replies.
5849
