April 25, 2024 at 4:39 am
Harris Teoh
SubscriberI was unable to perform bolt pretension on my ansys and i have explored many methods but cant work at all. Is there any one out there that is capable of solving this problem, your help means a lot to me.
the solution information keep showing "No pretension elements have been created. Please make sure that your Â
 input satisfies the pretension section definition requirements.   Â
and*** ERROR ***Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â CP =Â Â Â Â Â Â 0.656Â Â TIME= 12:34:24
 THE PRETENSION LOAD WAS NOT ABLE TO BE APPLIED. MAKE SURE THE LOAD   Â
 WAS NOT APPLIED TO A HOLE AND THAT THE LOAD IS NOT APPLIED MORE THAN  Â
 ONCE PER SURFACE.                  -
April 25, 2024 at 9:01 am
Aurojyoti Prusty
Ansys EmployeeHi,
It seems the issue lies with the geometry to which the load is being applied.Â
Same issue was reported earlier in the below links
Please make sure the pretension is being applied to cylindrical part.
Thanks
Aurojyoti
April 25, 2024 at 9:04 am
avnish.pandey
Ansys EmployeeHi,
May be you have not applied the pretension load correctly on the model.
Check the below forum discussion for more information.
April 25, 2024 at 1:29 pm
Aniket Chavan
Forum ModeratorAlso refer to https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v241/en/wb_sim/ds_Pretension.html for supported methods.
-Aniket
- The topic ‘Unable to run bolt pretension on my ansys’ is closed to new replies.
