3D Design
3D Design
Unable to place a fillet radius to the TEE pipe in ANSYS APDL?
    • jsv
      Hellow all, I was modelled the TEE PIPE unequal thickness in ANSYS APDL. I was unable to place fillet radius between the pipe & TEE stub ? I placed fillet radius assuming same thickness in Pipe & TEE stub and creating the issue if it has different thicknesses on pipe and TEE stub. I attached here corresponding error message and related plots. Any help regards this highly appreciated?
    • Devendra Badgujar
      Hi JITENDRA SATYANARAYANA Regarding your question on ANSYS Mechanical APDL, please post it on Ansys Customer Portal for support.  This ANSYS Discovery Community Forum is specifically for seeking help on ANSYS Discovery products. Thank you for your understanding! Regards.
      • jsv
        Devendra Badgujar thank you very much.
  • The topic ‘Unable to place a fillet radius to the TEE pipe in ANSYS APDL?’ is closed to new replies.
