Unable to open “data File quantities”
    • LuisOvalle449
      Hello I am having travel with the option file>data File quantities is inactivated. I already did the initialization.
    • Amine Ben Hadj Ali
      What kind of travel? Do you mean "trouble"? I do not understand your issue and I ask you for more details.
      Double check you have initialised the model. When I checked the option was greyed out until there was solution data available. If you look in "Results" tab can you plot a contour?
    • Karthik Remella
      Administrator
      Posting some screenshots will certainly help.
      Thank you!
  • The topic ‘Unable to open “data File quantities”’ is closed to new replies.
