October 15, 2024 at 2:31 pm
October 16, 2024 at 3:56 pm
Guilin Sun
Ansys Employee-
October 17, 2024 at 7:55 am
Serein
SubscriberThank you very much for your reply. I may not have described my issue clearly, which might have led to some misunderstanding. My question is that when I directly modify the frequency of the variable source in the S-parameter analysis group, I still see the frequency as 1e-12 THz when checking the source, which is clearly incorrect. For example, in the image below, I set the frequency of the S-parameter variable source to 10 THz, but the setting in the source remains unchanged at 1e-12 THz. I look forward to your response. Thank you.
October 18, 2024 at 3:55 am
October 17, 2024 at 7:30 pm
Guilin Sun
Ansys EmployeePlease open the analysis group, and check how does the input frequency is assigned to the source. Maybe it assues the frequency is in THz but if you show the data it would be in Hz.
October 18, 2024 at 2:29 am
2022022503
Subscriber我有试过,但是有个问题就是当我在分析组输入的频率不管是多少THz(只要单位是THz),其在源中都是1e-12THz不变
October 18, 2024 at 3:46 pm
Guilin Sun
Ansys Employee关于频率,你要看看是否在Model里面控制;
分析组里可以显示一下频率看看是多少。
如果还有问题,建议重新用空白新文件设置仿真文件。总是要找到能直接控制频率的方法。
第二,增加仿真时间没有什么标准,主要取决于结构是否有强谐振,不可以用器件厚度除以介质内速度计算。因为仿真是根据最小autoshutoff min停止的,你把仿真时间设置的非常长都不影响实际仿真,只不过软件估算的仿真时间不准确而已。
参见
Ansys Insight: 如何知道FDTD的仿真时间足够长
5719
